Boring cylinders
Posted: Tue Aug 04, 2009 6:18 pm
by 712 Walt
Had a valve drop into the #3 cylinder. Had to bore out cylinder #3 to 93.00 mm before it cleaned up. Is it necessary to bore out the other cyliners to match? They are in the 92.20 to 92.31 mm range and I am considering boring them out to 92.50mm and replacing the pistons.
Posted: Thu Aug 06, 2009 10:18 pm
by ExpeditionImports
Normal repair procedures would be to match your bore sizes.
Scott
Posted: Thu Aug 06, 2009 11:17 pm
by Profpinz
Posted: Sun Aug 09, 2009 9:55 am
by pinzinator
I agree with Scott and the Professor, the rotating assembly would be thrown out of balance if you proceed as planned. The piston and rings from each cylinder should weigh the same (assembled), within a few grains of each other. Not sure what the exact recommended tolerance should be.
