Solid Starter Mounts Available for gear reduction starters
bikmakr
Post by bikmakr »
I designed and made up a small run of these solid mounts. There have been instances of damage caused by the new higher torque starters shifting old or worn rubber starter mounts. In my case, it ruined my ring gear. I'm not sure why the designers ever came up with a "soft" mount. I suspect to isolate the starter motor from engine vibrations. I can't think of another vehicle that uses one.
This "kit" replaces the following stock items:
7121090142 ground strap $31.10
7121090162 rubber mount $82.02
9801362 bolt $.75
9001364 bolt $.85
7121090222 nut plate $22.59
Total $137.31
So for $110 plus actual discounted UPS, you can have a rigid set-up. PM me if you are interested.
Sorry, ships to US only. Overseas shipments can be too time consuming.
mmcc100
Re: Solid Starter Mounts Available for gear reduction starters
Post by mmcc100 »
Are these still available? I ordered a new gear reduction starter... I assume this will work for it. I haven't even looked at the condition of the old rubber mount, but considering any stress/damage prevention.
bikmakr
Post by bikmakr »
Yes, I have about 12 sets left. Email me directly for info.
Brandtw1@yahoo.com
Not sure how I missed this one but thanks for bumping it back up.
email sent
mmcc100
Post by mmcc100 »
Awesome! Email sent for an order.
bikmakr
Post by bikmakr »
I only have 3 left. Thanks for the orders. If you are thinking about ordering one, now's the time.
GadgetPhreak
Post by GadgetPhreak »
Did you get my email? I'd like one..
I sent an email too but no reply yet
Just resent from my gmail
Received mine today. Very nicely made!
Thanks!
tgreening
Post by tgreening »
I as well. Another project to add to the list.
bikmakr
Post by bikmakr »
OK folks, they are all sold. Thank you all.
Let me know if there is more interest and I'll make up another batch.
Brandt
mmcc100
Post by mmcc100 »
Got mine mounted and it's awesome! Thanks for your help getting the old mount off also Brandt!
bikmakr
Post by bikmakr »
bump
