WTB want to buy windshield tension brackets and knobs
NEWFISHER
Post by NEWFISHER »
Looking for the verticle spring loaded windshield retaining brackets that hold the frame when folded down. They mount between the headlamp and the grille. I also need a set of knobs that secure the frame when the windshield is raised upright.
I dont need the headlamp guards with the rubber footballs as I dont want to get into filling holes and repainting. I have an idea to fab a stop.
Scott at EI thought he had some but hasnt responded to emails or phone messages. SAV hasnt had any and buypinz Bob doesnt have a set but might have a lead.
Re: WTB want to buy windshield tension brackets and knobs
If you are going to fabricate your own supports for the windshield then I would suggest fabricating the hold down mechanism as well since they need to work together and it is not that fancy of a part.
As far as the knobs go - I've seen nice one with the puch logo on them - but you might be able to find something similar (without the logo) from a source like McMaster-Carr supply or similar.
You also might check with some of the European parts suppliers such as Haflingertechnic etc.
NEWFISHER
Post by NEWFISHER »
Thanks for the link. I would really like the o.e. ones.
Hotzenplotz
Austria
Post by Hotzenplotz »
newfisher
check out the manufacturer's site
http://www.puch.at/en/spare-parts/pinzg ... indscreen/
Albert
Post by Jim LaGuardia »
Here is the Steyr # for the Knobs with the Puch logo 7111721182 (fixing screw).
They are special order only as far as I remember.
Cheers, Jim LaGuardia
"Arch Magus of Machines."
Jim LaGuardia wrote:Here is the Steyr # for the Knobs with the Puch logo 7111721182 (fixing screw).
They also don't fit into a Swiss - you will have to drill and tap the existing holes
They are direct fit on the Swiss units, I have put them on several trucks in the past.
NEWFISHER
Post by NEWFISHER »
Thank you allnfor the info. I have sent emails requesting the parts, we will see whats still available.
If the knobs dont fit, I own a tap set ;)
Jim LaGuardia wrote:They are direct fit on the Swiss units, I have put them on several trucks in the past.
Well you would know better than I would :oops:
I was just going off of Rick's old thread http://real4x4forums.com/PinzgauerBBS/v ... 443#p33443
Thanks for clarifying
Post by pinzinator »
I did have to drill and tap, maybe I had a unique frame or set of knobs.
NEWFISHER
Post by NEWFISHER »
Found a set of knobs ( CWR ) and still on the hunt for the inner brackets and the outer hinged pieces or I may have to fab something.
