For those in the UK: https://www.i-bidder.com/en-gb/auction- ... 7e00c4b6de
https://www.i-bidder.com/en-gb/auction- ... 6a00f345fa
Interesting K. I assume this is a Swiss K with Austrian light guards and TD cowl/brush guard, with interesting wheel coverings and a "mini winch".
The description says the axles are "ABS".
710K and axles auction in UK
- original.jpg (107.9 KiB) Viewed 1843 times
- original.jpg (3.73 MiB) Viewed 1843 times
Re: 710K and axles auction in UK
The "K" has fuses - so wouldn't it be an Austrian version and not swiss? Just a different windscreen? Those wheel covers are odd - perhaps to reduce snow packing into the wheels?
Also - these are diesel axles I expect - so different diff and portal gear ratios? Or is it just the portal ratio that is different. At least they look well packed for shipping!
oh yeah prob so. I didnt look inside.
- Hotzenplotz
That model has been spec'd for non-military use straight from the factory.
Split windscreen is unique for Austrian army models, but the fuses typ is no indication. I have seen melting fuses and automats in various versions. The ashtray in the passenger side door also points at non-military specs..
The grill is a useless decoration....
Albert
Albert
