710K inside rear window
rdusek
Post by rdusek »
i'm looking for an rear slider window (inside piece) for a 710K, right side (if that make any difference). i'm located in las vegas
Re: 710K inside rear window
Assuming you are referring to the rear window glass, both panes are relatively inexpensive right from SAV.
rdusek
Post by rdusek »
oops, didn't see that on their drawing, so didn't look thru the parts available. thank you for calling that to my attention.
David Dunn
Post by David Dunn »
I might have some loose rear side door glass left. The last time I talked to Jim, he set there was a complete set out at his place in San Bernaradino of tinted
