SOLD- 1989 16" VW DOKA SYNCRO 3 KNOB
watergun
Post by watergun » Sun Dec 01, 2019 10:53 am
SOLD
"1989 Factory 16 Doka Syncro Triple Knob
4X4 SYSTEM MADE BY STEYR DAMILER PUCH
Price: $35,000 OR TRADE
WTS / WTT 1989 Volkswagen T3 Transporter SYNCRO, DOKA Factory 16” w/Decoupler, Go from AWD to 2WD, Front/Rear Differential Locks Plus Larger Brakes. Double Cab, Power Steering, Power Locks, Power Windows & Sliding passenger rear windows. Only 1 of 277 Made with These Options! Brand New Suspension Complete with All Power-Flex Bushings, Ball joints & Tie-Rod Ends. New Battery Complete w/Cut Off Switches & New 225/75/R16 Dyna-Pro Tires. 5 Sp. Manual Transmission with Low Gear. It is the body style that is rare and some of the options. However, everything else is VW Vanagon parts.
Parts and maintenance are easy to get and there is a ton of aftermarket parts and accessories available including Subaru engine swaps.
The Following Items are All New: CV Joint Boots (8 Total) for all Four Axles, Schwenk Syncro Springs with Correct 16” Factory Bilstein Shocks, Radiator, Heater Cable & Valve, All Cooling Hoses-(Some Rubber, Some Silicone with Upgraded Stainless Steel Cooling Pipes), MAF-Master Airflow System, All Fuel Lines, Bosch Alternator & Starter, Cylinder Heads, Engine Drive Belts, Catalytic Converter w/02 Sensor Installed, Water Pump, Thermostat & Oil Cooler, Upgraded Stainless Coolant Tank, Kydex Plastic Front Door Panels, Custom Bed Cover w/Heavy Duty 2x4 Aluminum Spar Supports, Dodge Caravan Folding front Seats w/Small Car Adapter Seat Brackets, Grill Guard for All Vehicle Running Lights, Front/Rear & Marker Lights. Clean Colorado Title.
Currently there’s 371, 146 Km on the Truck but a newer motor was installed prior to me buying the Truck out of Belgium and having it shipped to the U.S.A back in 2016. The newer motor was installed in November 2013 and is a used Factory 2.1 Liter VW Engine with 55,923 miles and I have added 28,371 since entering the USA for a current total of 84,294 miles. There’s been over $20,000 in upgrades since its arrival which were completed over the past few years. There is some minor surface rust on a few parts of the Truck, but the Body & Chassis are in very good condition. The truck runs excellent! The Dash Clock doesn’t work but I have a replacement.
All the European Maintenance Documentation from the previous owner from Belgium plus all current Maintenance Records are available.
Vehicle Trades I'm interested in (need something as a daily driver in AWD or 4WD):
Military Mercedes / Puch G-Wagen Swiss 230GE, or Austrian 300GD Long Wheel Base + cash
2010 or newer Honda Pilot or 2008 or newer Element in excellent condition + cash
2010 or newer Honda CRV or Toyota RAV 4 + cash depending on year, condition & mileage
2010 or newer Toyota crew cab Tacoma or Tundra + cash depending on miles year and condition.
Newer Ford F-150 / 250 / 350 crew cab Power Stroke or eco-boost +cash depending on year, condition, and mileage.
Also,
Possibly trade for Colorado mountain land but would still need 10K cash as part of the deal
VW DOKA 4WD SYNCRO
VW DOKA 4WD SYNCRO
VW DOKA 4WD SYNCRO
VW DOKA 4WD SYNCRO
VW DOKA 4WD SYNCRO
Kingpacific
Re: WTS/WTT 1989 16" VW DOKA SYNCRO 3 KNOB
Post by Kingpacific » Wed Dec 09, 2020 1:33 am
Would you trade for a 2002 Ford Excursion Limited V10 4x4 in good condition and only 120,500 miles?
Joeri
Belgium
Post by Joeri » Wed Dec 09, 2020 11:53 am
I wonder....is this Jan De Greef old doka syncro ???
