View unanswered posts | View active topics It is currently Mon Jul 24, 2017 2:34 am
Reply to topic  [ 2 posts ]
 Krawl gear kicks out unless i hold in gear. Adj tips?
Author Message
Post Krawl gear kicks out unless i hold in gear. Adj tips?
Anything i can do with the linkage to keep K from kicking out?
_________________
(2) 1968 Haflingers One For Sale
1979 Mini Cooper Ranger For Sale
1986 Corvette For Sale
2001 F250 Diesel and trailer
Current Company Cars
2017 MKT
2017 F-150
Sat Apr 01, 2017 3:07 pm
Profile
Post Re: Krawl gear kicks out unless i hold in gear. Adj tips?
Make a mark on the adjustment disk near the gear leaver tower so you can always go back to what you currently have.
Put it in neutral.
Loosen the bolts.
Hold the gearbox side of the disc still.
Get someone to hold the gear lever all the way to right (looking forward from the back of the vehicle) in the neutral line.
Tighten the bolts.
Try that.
If that doesn't work, then watch the rod movement at the gearbox tower when it is put in Krawler. Leave the system in krawler and disconnect the bolts completely. The gear lever should jump back to neutral if the spring is working.
See if stays in Krawler.
Then you will know if it is a problem deeper in the gearbox or just an adjustment issue.
John
Sun Apr 02, 2017 2:44 am
Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
