more oil dripping than i would like
- audiocontr
Re: more oil dripping than i would like
Do you apply gasket material around the return tube ball seal? I noticed someone did previously, but found no leaks when I simply flipped it over and reinstalled.
1978 GMC Palm Beach
2001 F250 Diesel and trailer
1978 GMC Palm Beach
Not quite sure what you mean there - I assume you mean the large rubber seals that seal the rocker oil return tubes where the tubes go back into engine block. If surfaces are clean you do not really need sealant on them as they squash up but as a precaution I do put a smear on them - the pushrod tubes also have a similar seal on them.audiocontr wrote:Do you apply gasket material around the return tube ball seal?
I have not had leaks from the oil return tube seals however as they squash up I have had one split which did cause a major oil leak but easily replaced.
Garry
1973 Haflinger AP700
1977 Landrover FC 101
2007 Range Rover Sport TDV6
1957 Landrover 88"
1957 Landrover 88"
