Distributor/timing from scratch, help
Posted: Tue May 01, 2018 8:24 pm
by OhioPinz
I removed my distributor without checking rotor position. How do I start from scratch and reinstall? What should the timing be set? I have a Pertronix that was running great but a screw fell out of the mounting plate and locked up the distributor- sheering the 3mmx20 pin holding the gear.
Re: Distributor/timing from scratch, help
Posted: Thu May 03, 2018 2:19 pm
by pinzi
Left cyl on TDC gives the mark on the double v pully standing against the mark on the coolerfan housing. Open the distributor and the finger should point about 6 a 7 mm before the mark on the distributor ( mark on top ) .
Posted: Fri May 04, 2018 8:08 pm
by OhioPinz
Thank you. That worked great. Back on the road.
