Main frame central tube - - lubrication ?
Posted: Mon Dec 09, 2019 12:11 pm
While topping off the 90W in the hubs, gearbox, and front dif, I noticed this plug near the top of the main tube about 8 inches back from the front flange. Looked like a fill port, so I pulled it. Using a wooden dowel, I found there was about 3/4 of an inch level of gear oil laying in the bottom of the tube. I have reviewed the Repair Instructions, Maintenance Manual and Spare Parts Catalogue (and these forums) and have been unable to find any references to lubricating oil use for the central tube. In addition, there appears to be no drain plug in the bottom of the tube as would be needed to change out the oil in the tube. A mystery.
See the attached. It is Part #27, which is listed as "drain plug". I have found that the phase "drain plug" is used in the manuals for both the oil drains and the fill ports.
So ..... Any feedback from you all on gear oil inside the main tube? And if so, how much? Maybe the oil slinger (#17) gives us a clue? Thanks.
Nelson - - San Antonio, Texas
