Use pinzgauer civilian conversion on halffie?
Post by audiocontr » Sat Jun 27, 2020 9:20 pm
One of my halffies has a military cap, but mcgyvered civilian wires and plugs. One of the wires is shot.
I've tried to MacGyver x2 and it's not working.
I have an old civilian conversion for my pinzgauer laying around. The cap adapter fits the halffie distributor.
Can I use the pinz civilian conversion on a halffie? The rotor clears fine. I figure I'll try the 4cyl cap and see how it goes.
(2) 1968 Haflingers 1 For Sale
1978 GMC Palm Beach
2001 F250 Diesel and trailer
Joeri
Belgium
Re: Use pinzgauer civilian conversion on halffie?
Post by Joeri » Sun Jun 28, 2020 2:33 am
Well if you can use the 2 oppesit points of the 4 cyl cap it should work :roll:
Post by audiocontr » Sun Jun 28, 2020 4:54 pm
It did work! Perfectly!
I converted a civilian ignition pinz to pinzssi. Had the the old distributor and kit laying around, including a pertronix.
Moved it all over to the haflinger and it works great!
I just covered the extra 2 ports on the cap
1978 GMC Palm Beach
Garrycol
Post by Garrycol » Sun Jun 28, 2020 8:58 pm
Of course if you use a wasted spark coil you can run a Haflinger engine without a rotor or dizzy cap - just put the cap on to keep the dirt out.
https://www.youtube.com/watch?v=0dZghmByvHU
1973 Haflinger AP700
1977 Landrover FC 101
2007 Range Rover Sport TDV6
1957 Landrover 88"
Post by audiocontr » Mon Jun 29, 2020 6:27 am
What type of devilry is this!? How??
1978 GMC Palm Beach
Garrycol
Post by Garrycol » Mon Jun 29, 2020 8:55 pm
Magic - all you need is a dual output wasted spark coil pac :D . As both spark leads fire at the same time, on a 2 cylinder engine you do not need a cap or rotor - fires just on the points - but fires both cylinders at the same time.
1957 Landrover 88"
