Use pinzgauer civilian conversion on halffie?
Posted: Sat Jun 27, 2020 9:20 pm
by audiocontr
One of my halffies has a military cap, but mcgyvered civilian wires and plugs. One of the wires is shot.
I've tried to MacGyver x2 and it's not working.
I have an old civilian conversion for my pinzgauer laying around. The cap adapter fits the halffie distributor.
Can I use the pinz civilian conversion on a halffie? The rotor clears fine. I figure I'll try the 4cyl cap and see how it goes.
Re: Use pinzgauer civilian conversion on halffie?
Posted: Sun Jun 28, 2020 2:33 am
by Joeri
Well if you can use the 2 oppesit points of the 4 cyl cap it should work
Posted: Sun Jun 28, 2020 4:54 pm
by audiocontr
It did work! Perfectly!
I converted a civilian ignition pinz to pinzssi. Had the the old distributor and kit laying around, including a pertronix.
Moved it all over to the haflinger and it works great!
I just covered the extra 2 ports on the cap
Posted: Sun Jun 28, 2020 8:58 pm
by Garrycol
Of course if you use a wasted spark coil you can run a Haflinger engine without a rotor or dizzy cap - just put the cap on to keep the dirt out.
https://www.youtube.com/watch?v=0dZghmByvHU
Posted: Mon Jun 29, 2020 6:27 am
by audiocontr
What type of devilry is this!? How??
Posted: Mon Jun 29, 2020 8:55 pm
by Garrycol
Magic - all you need is a dual output wasted spark coil pac
. As both spark leads fire at the same time, on a 2 cylinder engine you do not need a cap or rotor - fires just on the points - but fires both cylinders at the same time.
