Steyr puch fans must together keep - worldwide!
We did like
Hafy rings, valves and guides
Re: Hafy rings, valves and guides
Steyr-Puch Haflinger Swiss Army 1962
Steyr-Puch Pathfinder 1972
http://sahler-bernd.wixsite.com/haflinger-verdeck
- westernair
I love finding NOS parts. The intake manifold is for a webber carbed hafi. The tail light is for my Pinz.
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
Recently speaking to the previous owner of my Haffie who did a major rebuild on the engine a couple of years ago. I found out that my engine is 762cc and has 87mm bore courtesy of VW pistons and "Marley" barrels (what are these??). The engine was fully rebuilt but I do not know what other enhancements like valves etc were done to the engine.
It has a larger Solex 34 PCI carby and a 123/Fiat Electronic ignition system and a larger exhaust from the manifold back.
I have no idea what sort of extra power it makes and cannot compare it to another Haffie as I have never driven another one - however what I can say it could still use more power - but then again things might get scary. The previous owner did say it will do 90kph on 14" tyres but as it is not registered for road use I have not been able to see if this is true. One thing I have noticed is that the engine does load up and when in the wrong gear - like climbing a hill offroad in 2nd when you should be in 1st - it overfuels and is sooting up the spark plugs and takes a little while to clear - goes Ok in 1st though but I have yet to master the knack of being able to select 1st when I want rather than just occasionally.
Garry
Garry
1973 Haflinger AP700
1977 Landrover FC 101
2007 Range Rover Sport TDV6
1957 Landrover 88"
1957 Landrover 88"
Try Google with Mahle barrels
http://www.mahle.com/MAHLE/en/Home_EN
That is a nice surprise to find out about your Hafi!
I find I only use 1st gear going down steep hills - otherwise I am in 2nd going up steep stuff
Thanks - I had tried google but with the spelling I had and drew a blank.
We often are critical of the power of a Haffie engine but in researching what VW etc that my pistons were out off I looked at the power outputs of VW engines of around 1200 - 1300cc from the same era and see that the power output of the smaller (late model) Haffie engine was very competitive with a VW engine of twice the size and of other similar engines in other makes. So I think the designers did a pretty good job with the engine.
Garry
Garry
1957 Landrover 88"
1957 Landrover 88"
I guess in todays world it is all about top end speed.
There have only been a few times where I wish I had a little more speed or power but to be honest my Hafi keeps up with traffic just fine and can blast down ATV/snowmobile trails way faster that I need/want to go!
I can easily do 40mph (65kph) with the 13" rims and for me that is fast enough in a tiny Hafi!
Not sure what some people want to do in these vehicles - travel on a highway?? ??
- westernair
40 is my top speed but the engine is capable of pushing her 60. Anything faster then 40 i would be afraid to flip It.
I like going up the steep hills in my neighborhood at or about the speed limit.
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
I have only ever got my Haffie up to about 50kph and it feels absolutely dangerous at that speed - very unstable and twitchy in the steering so I agree that without major work on the brakes, suspension and wheels/tyres higher speeds are not a good idea - if you do these mods you then take away the character of the vehicle which then begs the question why have one.
I am surprised at the hard ride when off road but its small size and tight turning circle are a real bonus however it could use a bit more torque at low revs and a bit more stability. I am used to driving forward control vehicles as I have Landrover 101FC as well which can be hairy to drive in some circumstances but the Haffie is a lot worse but at least if it tips it is easy to tip back upright. I also find the Pinz compared to the landie positively dangerous stability wise when in steep offroad situations.
I suspect that my Haffie previous owner in enlarging the engine with 87mm pistons was looking to increasing that low down torque - certainly in my limited experience the engine on the road is not reving a lot higher before changing gears than you would with a standard engine and the max revs I have seen on the road is 4800rpm and I do not have a governor.
To change the basic character of the Haffie would be a shame - my Haffie fits in my box trailer and I did a test tow a couple of days ago and all went OK so I have no real need to do "high" highway speeds in mine.
Garry
Garry
1957 Landrover 88"
1957 Landrover 88"
