Haffy on tracks
cubdriver55
Haffy on tracks
Post by cubdriver55 »
I am looking for an off road vehicle that is better built than the modern 6 wheelers. I am considering a Haflinger but in the spring I need something I can put on the aftermarket tracks. Has anyone ever put aftermarket tracks on one and if so where did you get them? Has anyone put tracks on a 710? thanks Steve
Garrycol
Re: Haffy on tracks
Post by Garrycol »
1973 Haflinger AP700
1977 Landrover FC 101
2007 Range Rover Sport TDV6
1957 Landrover 88"
rustywheel2004
Re: Haffy on tracks
Post by rustywheel2004 »
There is also a video somewhere on YouTube of a Pinz with track system.
However, these tracks on a Haflinger are a recipe for disaster. Notice in the video that the motor is revving very high as there is barely enough power to move this much equipment. Also, stay tuned for an ad from the owner desperately seeking new hub gear housings and shafts as his originals will self destruct quickly with this much torsional load. :(
By the look of the amount of track spin shown in the video I'd say that a Haf with original Semperit tires handles the snow better than these tracks.
Steve
1971 NA 700AP
David Dunn
Re: Haffy on tracks
Post by David Dunn »
I am not sure what your idea is of a "modern" 6 wheeler, as most are 'toys'.
In the " other 4x4 section", there are 3 (OT) threads on Supacat ATMPs.
Not knowing what and where you plan for it, I could only guess if one is useable for you.
Even at 4200 lbs, they are still faster on the road than 99% of the Haffies (even while carrying a loaded Haf :lol: )
And swim with a reduced payload cap (900 lbs)
M Wehrman
Re: Haffy on tracks
Post by M Wehrman »
You can also get an Argo w/tracks. :D That was for you Dave! :lol:
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
Re: Haffy on tracks
I suspect that Steve is right, these are probably very hard on the axles. But the reving comes partially from the much smaller diameter drive wheel (about half the diameter of a normal road wheel so the tracks basically cut the top speed of each gear in half) and partially from the right foot having fun!
David Dunn
Re: Haffy on tracks
M Wehrman wrote:You can also get an Argo w/tracks. :D That was for you Dave! :lol:
:? and you thought I didn't know that?
Cubdriver55 was looking for something "better built" than the typical 6 wheelers with their over sized lawn mower engines... I had even thought about getting a Centuar at one time.... a very short time :roll:
Re: Haffy on tracks
6x6?? Why not just buy a snow-cat? Mine's 10x10 with tracks. :wink: Okay, 10x2 with tracks...
Re: Haffy on tracks
Another I found for what is worth
http://www.youtube.com/watch?v=YtsoUpFDmwo
I also like the custom top on it
