Twisted just a little too hard - Weber 32ics accelerator pum
Posted: Sun May 25, 2014 8:53 pm
by Haffy Mark
Hello -
After going through some hard times and letting the Haffy sit a few years, I decided to wake it up. Drained the fuel and cleaned the carb and when I was putting the accelerator pump nozzle back on I broke the screw/jet. Does anyone know where I can get one?
Thank you,
Mark
Re: Twisted just a little too hard - Weber 32ics accelerator
Posted: Mon May 26, 2014 3:40 am
by Heinkeljb
I am sure one of the European suppliers will have one. How about this one?
http://www.puch500.at/?action=vergaser
John
Posted: Mon May 26, 2014 10:23 am
by Haffy Mark
Thank you John. I did try them but I didn't see the part. I do have a parts list for HT but I can't find my parts book so I'm not sure of its name or part number.
Thanks again
Mark
Posted: Mon May 26, 2014 12:10 pm
by Heinkeljb
My parts book only has Zenith NDIX 32 part numbers in it and I don't see a part that matches your broken one I'm afraid. Hopefully someone else has a a part number for you.
I am sure one of the European supplies has these as getting small things made in brass on a CNC lather is not as expensive as having castings or gears made, so they can be bothered to get them made.
John
Posted: Mon May 26, 2014 11:45 pm
by Jim LaGuardia
Please add location to your profile to be directed to closest resources. If all else fails, give Dale at Haflingertechnik in Scotland a call for your nozzle screw/check valve.
Posted: Tue May 27, 2014 12:08 pm
by Haffy Mark
Thanks Jim. I went ahead and did it.
Posted: Tue May 27, 2014 3:31 pm
by Jim LaGuardia
What year/model is your Haflinger? If you ever want a nice easy scenic Haflinger trail ride, I am 5 min from very nice trails.
Posted: Tue May 27, 2014 9:41 pm
by Haffy Mark
That sounds good Jim. It's a '67 Swiss troop. I put magnesium Fiat wheels with snow tires. They work so well off road I decided to leave them on.
I'm going to add the pertronix once I get it running again. I'm also looking for a synchro set 1st and 2nd are pretty bad.
I'm not too far from you. Would love to get in on a trail ride!
Posted: Wed May 28, 2014 3:43 pm
by Jim LaGuardia
The part is called a "pump pressure valve" in the repair manual. The part number only exists in early part catalogs, Pre 1970.
Posted: Wed May 28, 2014 4:47 pm
by Haffy Mark
Thanks Jim. I emailed Haflinger Technik that description. I need a float too, so hope they have one.
Thanks again
Posted: Thu May 29, 2014 8:40 pm
by Haffy Mark
I got a reply back from Dale at HT. He has them in stock
I'm just waiting for a reply on how to purchase that and a few other parts. Thanks for the help guys.
