As I'm converting my 718M to a K configuration I've been CAD drawing many of the components either to check assembly or for laser cutting and folding purposes.
I always intended, that at the same time as rebuilding the real thing to develop a complete, accurate CAD model of the 718 using this data, and over the last few weeks I've begun assembling the bits and pieces I've drawn to date....so I thought you might like to see the progress
The diff casing as is a bit of an experiment, as it still needs a LOT of work, but eventually I'II have a virtual 718 as well as a real one.
718 Restoration Spinoff
http://www.ozpinz.com
Re: 718 Restoration Spinoff
Curious as to what software you're using. Can you output .STP, or .IGS?
'76 710K
I'm using Ironcad (similar in many ways to Solidworks)
Yes, it can output Step and Iges files.
