Paerts, bits and pieces, etc etc
Re: Paerts, bits and pieces, etc etc
M&H towing plate
A little longer
A little longer
Regards
(Project Gimpy 2)
(Project Gimpy 2)
Still plodding along
Engine
Anyone got one of these laying around? Funny enough I just heard a rusty one got chucked in the bin. Often fitted to Swedish version to heat the engine and very often rusty
Started with a 4x4 and now got this, madness
Engine
Regards
(Project Gimpy 2)
(Project Gimpy 2)
Timing belts
P90 075109119B has 119teeth, 1133.5mm length, Goodyear G1155
P93 075109119C has 120teeth, 1143 mm length, Goodyear G1161H.
The rear is 75teeth, 714mm length for both applications.
Regards
(Project Gimpy 2)
(Project Gimpy 2)
Well got picked up 2 pieces of functional bling today in what we term M&H alloy auto gear shift cover. First look they are quite good, but still need polishing and or coating. Will go see if everything fits tomorrow
They are quite thick so should be indestructible.
Regards
(Project Gimpy 2)
(Project Gimpy 2)
Cool Gearshift cover, I want one ???? $$??
Had a few people ask about them now. I haven't finalized the price as yet as I am travelling at the moment but around the same price as the plastic bit which is around 80-90 Eurohardro33 wrote:Cool Gearshift cover, I want one ???? $$??
It was something I always wanted to replace but ended up being spur of the moment affair as asked a guy and said yep no problem... Will know more when I get home
I did drag one all the way to UK to pass to the guy who bought my 4x4
Regards
(Project Gimpy 2)
(Project Gimpy 2)
SUGGESTION FOR WIPER BLADES AND ARMS?
I have not completely finished this yet but bought some spindle bush replacemement type things, (I have used on old land rovers in the past) it locks on the spindle shaft and provides new splined shaft. ( I checked this and it does fit on 710 splines)
I have compared the pinz arm and wiper to the land rover one, and guess what pretty much the same.
New landrover arms and wipers then should fit.
As I said i havent finished this yet, still to get arms and wipers to complete job, but can see no reason why it does not work and fit.
Replacement land rover blades cost is very low.
Yep let us know how it works as the Pinz size is quite odd to get over my way
Regards
(Project Gimpy 2)
(Project Gimpy 2)
