air con
air con
Hello, Help!!
just had a red dot R-6100 roof top air con unit fitted.have also replaced the left engine mount for the for the one with the compressor fittings.having great difficulty in finding a compressor that will line up to the crank pulley,without further fabrication.are there any off the shelf compressors that will fit? my pinz is 12v. currently in the UK.
Thanks to any one who can help.
Regards.
Garymartin.
Regards.
Garymartin.
Have you checked any of the VW LTs, or Volvos that use the same engine? There is next to nothing over here that uses the 2.4 engine other than the '80s Volvos... and not too many of them either.
air con
Hi,
Thanks Dave I will check some vw sites over here.
Hi, Ugo, I have parts manual, and access to yahoo forum, the compressor part # are for a 24v compressor,have been in contact with S-TEC in Austria they do not stock or have any part # for 12v. So i am thinking engine mount braket is set up for 24v compressor only. So further fabrication might be the only option! My pinzi has been in a red dot recomended suplier/fitter for10 days now(in Kent),dont think they anticipated any difficulty in fitting.(totaly missed war & peace show.)
yes Ugo I will share my experience about the insallation, at the moment its VERY FRUSTRATING. Any further help will be most welcome.
Regards
Garymartin.
Regards
Garymartin.
12V and 24V compresors differ only in the solenoid which cause the cluch to engage / disengage.
Maybe you can find a 12V solenid for replacement.
Another chance would be contacting Ms. Bertalanics at SDP. They do have part numbers for 12V components (actually, they helped me for some 12V relays for daytime running lights activation I have in my civilian 716k).
Ugo
Ugo
air con
Thanks Ugo,
will contact SDP today.
GM
GM
air con.
Hi,
Just to let you know,Have just returned from garage, with complete & working air con unit.drove about 150 miles, unit seems to be working great,had to turn it off at dusk as was getting a bit chilly.finaly used a seltec 488 4501 compressor & some bracket fabrication,will inspect tomorrow & take some pics.
Regards
GM
Regards
GM
AIR CON
Hello fesm_ndt sorry about the delay in a reply but things are very hectic at the moment.No pics yet, will take some this weekend weather permitting.the box on top is made by red dot corporation,(recommended by Mr Dunn) Model R-6100. I need to re insulate the cab area and engine covers,erect some kind of curtain behind rear side doors to enclose front area, will also look at some ideas of getting rid of more heat from engine area.
Hello hardro33 have sent you a PM.
Regards
GM.
Regards
GM.
This is from Gary
I'm not positive, but I will check. I think the mounting bracket may be the same as what was fitted to the Swedish Pinzes for the secondary Bosch pump for the hydraulic winch.Here are some pics of my air con unit. Red dot R-6100, compressor Seltec
45011.fitted to engine mount part #7161130212, after some difficulty fitting
the compressor some further fabrication on a bolt under compressor was
needed (sorry no pics).on inspection yesterday, noticed slight chaffing on a
hose caused by comp belt, have since tied hose/cables further away from
comp. This was all fitted by a UK company based in Kent.
air con
Having removed one of the swedish hydraulic winches I can say that the compressor looks to be mounted in the same place as the hydraulic pump, so it's either the same bracket one a new one fabricated to fit in the same position.
Yes, I removed the pump on the Pink Cow too, but left the bracket on the engine, in case I decided to add it back or install a/c . .....but that is a bit of a moot point with a softtop. ...
I'll try to look at my engine compartment in the next few days to identify the bracket
