Gas Heater fuel adjustment
dadnova
Post by dadnova »
My heater smokes quit a bit, can someone tell me how to adjust the fuel amount or where it should be set at?
Thought I would ask before I start playing with it.
Re: Gas Heater fuel adjustment
Smokes through the exhaust or interior?
Mine always has a lot of exhaust smoke - its diesel
dadnova
Post by dadnova »
It smokes through the exhaust pipe, but the smoke can then enter.
It should not smoke that much.
dadnova
Post by dadnova »
Or does it need to be removed and just cleaned and rebuilt?
Does anyone know?
I don't know what adjustments are available for the BN4 heater itself; you may have to adjust the fuel pump for less fuel flow. Mine never had even a hint of smoke when it was running, but I've not run it in many years now - I know that it drips gas and I haven't bothered to mess with it.
boeing7873
Argentina
Post by boeing7873 »
Did you ever solve the smoke problem? I am dealing with it now. Don't know how to adjust the mixture if it is possible.
JC
Jerome
CRJ Driver
boeing7873
Argentina
I suspect the dosage pump may not be operating correctly.
Jerome
CRJ Driver
dadnova
Post by dadnova »
Mine put out black smoke I adjusted the screw, from your picture on the far left, turn it out if possible. I reduces the spring tension on the diaphragm. Mine went from black to clean, but my screw was all the way in?? That way when I bought the Rig.
