winch mount.....
waterdog
Paraguay
winch mount.....
Post by waterdog »
for you guys who have a winch mounted in front of the grill,, doesnt make any restriction on airflow for cooling??? any difference??
1985 710MS
1985 712MK
Jack Russell Racing
Re: winch mount.....
Post by Jack Russell Racing »
waterdog wrote:for you guys who have a winch mounted in front of the grill,, doesnt make any restriction on airflow for cooling??? any difference??
No noticeable difference on my 710M. I have a winch from Andre (Fat Fabrications) and a WARN XD9000 winch.
If you search you should be able to find older posts on this.
Conclusion was it makes no difference in cooling
No difference. Air is also pulled in from the bottom of the engine area. I had my 710 M running in the desert of SoCal and Death Valley where it was so hot that touching the metal body would burn your skin...115 deg F easy for air temp. No issue with winch in front.
waterdog
Paraguay
Post by waterdog »
Good to know from your experiece guys ,cause down here gets hot and doing slow traffic worries me :?:
, thanks.....!
1985 710MS
1985 712MK
