Top Speed
Doug308
Top Speed
Post by Doug308 » Wed Jul 04, 2018 8:15 pm
Okay, so playing with my new to me 710 M and thus far I have only felt comfy taking her up to about 45 MPH. And frankly, it doesn't feel like it wants to go a helluva faster than that speed. This is on level dry pavement. She's not making any funny noises, smoking, or doing anything else weird, and I am sure that I have it in fifth gear. Also I do not have any of the diffs locked.
My reading on the subject suggests that she should be able to get up to 55 plus under these conditions. Is this correct?
"When I was 13 I thought my father was the dumbest man alive. By the time I was 21 I was amazed at how much he had learned."
Mark Twain
Re: Top Speed
Post by rmel » Wed Jul 04, 2018 9:39 pm
In 5'th gear with ~33" Tires @ 55 MPH = 3300 RPM.
What's your Tachometer reading at 45 ?
Rescue Pinz: 73' 712M
Re: Top Speed
Post by David Dunn » Wed Jul 04, 2018 10:08 pm
Pinzes are military vehicles and have no sound deadening, and engine, drivetrain and tires scream at high speeds. 55 to 60 shouldn't be any difficulty. My old 710M was capable of well over 70 (255/85 tires). Without a tach on it, you need to be sure the speed limiter warning lamp works, comes on at 4500rpm +/-. Trucks in some disrepairs won't turn highway rpms. If nothing else, put a tach on it so you can have a feel for the engine noise at over 4000 rpm, that may give you an idea of the noise level. The noise is discerning to many, but these are old vehicles and not designed for economy or modern road speed, typical convoy speeds would been at below 55 mph
Re: Top Speed
Post by David Dunn » Wed Jul 04, 2018 10:13 pm
Ron
You're running TD transmission and 5th is .78 +/- overdrive. 4th is the same as a 710/712 transmission
Re: Top Speed
Post by rmel » Thu Jul 05, 2018 12:53 am
Yes, I am running the TD, and in 5'th gear @ 60MPH I'm CRANKING at 2800 RPM.
With the stock tranie, 5'th gear @55 = 3300 RPM, @60 = 3600 RPM. IMHO, with
the stock tranie, I'd keep it at 55 or less.
Re: Top Speed
Post by VinceAtReal4x4s » Thu Jul 05, 2018 2:22 am
Try rolling your top back then test drive it. Youll likely feel better about doing 55mph. Those slick tops reflect all that sound right back into the cab.
Real4x4 Facebook https://www.facebook.com/real4x4s
Re: Top Speed
Post by edzz » Thu Jul 05, 2018 11:38 am
Acceleration to highway speeds is not rapid however you should not have problems getting there however IMHO ear plugs are a must for any extended travel over 40, 45 mph.
Ed
75 710K (sold)
06 2WD Ural Patrol (sold)
69 2WD Rokon Trailbreaker 4 sale
A few Honda Trail 90's (all sold)
Re: Top Speed
Post by rmel » Thu Jul 05, 2018 1:05 pm
I should have added a couple of other points about speed >55 Mph.
Noise and Engine RPM being two, but the other is Wheel drive wear
and tear -- there's very little oil in these wheel drives. Of course the
other reason is stability and safety.
With respect to noise, easier on a K than M, but toss in 100 lbs or
so of sound deadening materials and anti-vibration foil will make
a huge difference. I keep forgetting all the mods in my rig that I
take for granted -- low noise being one, well, relatively speaking.
With the TD Tranie, and 2.7L I do cruse comfortably at 60 mph on
the HWY -- grade permitting. I never go over 50'ish on step winding
down-grades, slow and safe. My best friends on the HWY are big rigs,
draft behind them at 55 or so. Of all the truck companies Schneider
sticks to the speed limit +- 1 Mph, best drivers I have lagged :wink:
Doug308
Re: Top Speed
Post by Doug308 » Thu Jul 05, 2018 2:24 pm
My bad kids. Appaently one of my darling chidren had through the Hi/Lo lever. After beating the kids shufting back into Hi it now cruises 55-60 no sweat.
Mark Twain
Re: Top Speed
Post by edzz » Fri Jul 06, 2018 1:31 am
That's right blame the kids. :)
You lie about it and I'll swear to it. :lol: :lol: :lol:
Ed
75 710K (sold)
