Can anyone help with some translations from the vehicle identification plates? This is a continuation of the requirement of our DMV to issue a new VIN for my Pinzgauer 712AMB. The total GVW seems too light for a 712. Here is the info from the plate by the driver's seat:
zulass. vorderachslast kg . . . . . 1500
zulass. hinterachslast kg. . . . . . 2600
zulass. gesamtgewicht kg . . . . . 3500
I would guess that this would be front axle, rear axles, total.
The plate on the door reads:
Leergewicht kg . . . . . 2850
Gesamtgewicht kg. . . 3500
I would assume that this would be curb weight and GVW - again awfully light. The operators' manual says the "permissible total weight" for a 712 is 3900 kg - 4200 kg depending on model.
Thanks for any help,
Lloyd
Translation help
Translation help
OK, just checked a 712M for axle ratings. It had exactly the same front and rear axle load ratings as the 712AMB (1500 kg and 2600 kg) but had a much higher GVW (4000 kg vs. 3500 kg). I still suspect there may be some European weight restrictions affecting either road access or licensing requirements for vehicles exceeding 3500 kg GVW.
Lloyd
Lloyd
