Running a Little Lean
I think the motor might have been running a little hot!
http://www.ozpinz.com
- David Dunn
Come on Jim, you remember the CARB NOX kits of the 70's..... it raised the engine temps, oh so slightly, to complete the combustion of unburnt fuel before it exited the tail pipe.
From that pic, the kit did everything CARB wanted it to..... eliminate unburnt fuel into the air, AND get gross poluters off the road..... So what's the problem?
Re: Running a Little Lean
Brain, how can you expect Jim to diagnose how lean it's running from a picture? BTW, I like the custom carbs and fan shroud.AZ712DK wrote:Noticed a little problem with engine power then I realized it might be running a little over heated. Jim L. do you think I might be running a little on the lean side (see photo's).
Brian
http://www.flickr.com/photos/37990362@N ... otostream/
