He must really hate the front bumpers...
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
Robin
Pinzgauer 710K
MegaJolt ignition
Re: He must really hate the front bumpers...
Been there... done that... got the T-Shirt
Ouch! Why's the wheel at that angle? What snapped/bent?
Robin
Pinzgauer 710K
MegaJolt ignition
Robin
Pinzgauer 710K
MegaJolt ignition
That was 2 axle drive housings that broke at the sheer pin(rt front, rt center) when the tires contacted the body.
Cheap and easy job to fix then
Robin
Pinzgauer 710K
MegaJolt ignition
Robin
Pinzgauer 710K
MegaJolt ignition
If you call a few thousand dollars cheap
- GenevaPinz
Is this because of oversized tires?Jim LaGuardia wrote:That was 2 axle drive housings that broke at the sheer pin(rt front, rt center) when the tires contacted the body.
Jan
'72 Pinzgauer 710M
'72 Pinzgauer 710M
That would be an obvious yes Of note, the trail conditions were brutal and the Truck was very heavy. A lighter truck may have made it with the same tires. Load always plays in as a factor in these types of failures.
- GenevaPinz
Thanks for the details... sounds obvious indeed (especially now that you confirmed ), but I tend to remain cautious in my questions. You know the Mark Twain quote: t's better to stay silent and look a fool, rather than speak and remove all doubt!Jim LaGuardia wrote:That would be an obvious yes Of note, the trail conditions were brutal and the Truck was very heavy. A lighter truck may have made it with the same tires. Load always plays in as a factor in these types of failures.
Jan
'72 Pinzgauer 710M
'72 Pinzgauer 710M
