The Weber Hydraulik jack off of my Pinz has finally given up the ghost. The local hydraulic shop did a rebuild with new seals, but it is still leaking. Now is the time to stop the money hemorrhage and get something new. However, I can't find another working used Weber anywhere.
Are there any other good jacks that work with the Pinz? I tried a Hi-Lift, but it was unstable and dangerous.
Thanks for the info.
Pinz Hydraulic Jack Replacement
John Cotner
New Ulm, MN
John Cotner
New Ulm, MN
Take your pick
http://search.harborfreight.com/cpisear ... &Submit=Go
The 6-ton or the 8-ton should work OK.
Under the rounded portion of the axle half shaft. There is a flat portion down there that looks like it would work with a normal jack, but I was reluctant to jack there. I'm finding the same problem with jacks around here: not enough height. The tallest I've found are around 17". And even with a 6x6 underneath, it would still be only be 22 1/2"
John Cotner
New Ulm, MN
John Cotner
New Ulm, MN
