New to the board, air suspension modified M710
Congrats on the new "Sweetish" toy! What condition is it in? what are your plans? Going to add an AC unit, or cage, like the 712?M Wehrman wrote: She will be topless for a while,but the box arrives tomorrow. To surmise,My topless Swedish friends box will be here tomorrow
todds112:
PM Sent
Erik712m:
Yes, agreed.
Mechanically it,s quite good,some rust issues but no big deal.The big issue is it is painted a pea green metallic and a poor job at that.
looking to make a camper,a/c ,generator,water tank,etc...make a mini motorhome! Trying to make things more comfy for my bride..Now I need to build her laundry room the way she wants it. She originally said no more trucks until I finished that job. I used my usual charm and presto! I have a Volvo! She is way too nice to me.....
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
68 Haffy
Sounds like jeeps army rescue green?The big issue is it is painted a pea green metallic
Lucky you the wife told me, I had to sell one before I could buy another one.She originally said no more trucks until I finished that job. I used my usual charm and presto! I have a Volvo! She is way too nice to me...
This suspension system wasn't designed to be able to make the Pinz Jump... you'd probably want hydraulic rams or something ... But we can change both of the rear tires (one at a time) without a jack. We just deflate one front side and inflate the other front, as well as inflate the opposite rear side... the result is the rear tire lifts off the ground enough to change it...norcal pinz wrote:can you make a pinzgauer jump with something like this setup, i would love to see a pinz with powerful enough hydraulics to make it bounce
That is cool!!! Really wasn't entrusted until you mentioned that
I've struggled changing tires in the middle of know were. find enough large rocks to put under the jack so that it will extend enough to put the spare on.But we can change both of the rear tires (one at a time) without a jack. We just deflate one front side and inflate the other front, as well as inflate the opposite rear side... the result is the rear tire lifts off the ground enough to change it...
You could still freak people out. The Pinz draws alot of attention anyway. Imagine being at max lift at one light and bottomed out at the next light next to the same car from the previous light. Or maybe pull up with a pronounced list to the port side.
Couple big hunks of 4 X 6, or a 4 X 6 and a 2 X 4, will usually get a jack in place.
Andy
Andy
Here are two photos with a measuring tape:
Fully air'd down:
Fully air'd up:
Although its not the recommended method for changing a tire, the system can put a rear tire in the air. Here is a video of lifting a rear tire:
Pinzgauer M710 Lifting a rear tire
Fully air'd down:
Fully air'd up:
