Accesory plug behind the 4wd locking levers??
- audiocontr
I just noticed i have an accessory plug behind the plate that the levers mount to. Its all the way in the back (or front i guess) directly under the heater hose. My 710 did not have this. Whats it for?
It's for the night convoy light, that was mounted thru the hole in the grill.
![Image](http://lh5.ggpht.com/_XWg1gU1bIW4/SjR1FyptLsI/AAAAAAAAELI/NI0TzTrv0CE/s800/PaintMid_04.JPG)
Miles
Miles
'73 Pinzgauer 712M
'73 Pinzgauer 712M
There should be a plug into that outlet, and I do think it works the Night convoy light - which still works - try some night on a dark night in an area with no street lights. I was amazed at how much light it put out.
You have to depress part of the head light switch and turn it the opposite direction to activate the convoy light.
Pinzing is AWESOME.
Night convoy light- what color?
Is that the light with the black hood- what color is the light?Kirby wrote:There should be a plug into that outlet, and I do think it works the Night convoy light - which still works - try some night on a dark night in an area with no street lights. I was amazed at how much light it put out.
My 710K has funky blue-purple night lights in back- not the red night lights I'd expected (- from a past life in USN aviation and ships).
Re: Night convoy light- what color?
Pinzing is AWESOME.
- audiocontr
Skeej wrote:Is that the light with the black hood- what color is the light?Kirby wrote:There should be a plug into that outlet, and I do think it works the Night convoy light - which still works - try some night on a dark night in an area with no street lights. I was amazed at how much light it put out.
Those funky purple lights are black lights. I'd like a few in my 712!
okay, adding to the wish list- hooded funky bluish-purple light in the grill-audiocontr wrote:Skeej wrote:Is that the light with the black hood- what color is the light?Kirby wrote:There should be a plug into that outlet, and I do think it works the Night convoy light - which still works - try some night on a dark night in an area with no street lights. I was amazed at how much light it put out.
for creeping about in the desert, lights out...hehe
FWIW, I found a Grote LED blackout light on Ebay a while back, for a decent price. Green colored lights, and it fit right into the Pinz grill. I also fitted a 24v relay inline, and it's got both normally-open and normally-closed terminals. So I hooked the blackout light to the normally open terminal and the backup (reverse) lamps to the normally closed terminals. That way, when I go into blackout mode (which we all know we need!
), the backup lamps die.
![Cool 8)](./images/smilies/icon_cool.gif)
