front wheel drive
- bababiscuit
front wheel drive
My front wheel drive indicator light is staying on all the time...any idea what this is indicative of and how to remedy it?
Re: front wheel drive
You are (1) in low range or (2)may have a vac leak or(3) switch malfunction(behind the e-brake backing plate).
When no vacuum is present, the front drive is engaged.
Notes:
Front drive is always engaged in low range or when parked(engine off).
The switch under the right rear jump seat controls the solenoid, the main vac line to controls is to right rear of engine compartment, just follow the hose from the intake source![Wink :wink:](./images/smilies/icon_wink.gif)
One last item, please put your location in your profile.
Notes:
- bababiscuit
thanks for the reply, Jim...parking brake indicator light now staying on as well...related?
Check brake fluid level and e brake switch.
- bababiscuit
Cheers Jim!
