Clutch Master Cylinder
How does one access the front end of the clutch master cylinder to remove the unit for rebuild? Does something else have to be disassembled ?
Re: Clutch Master Cylinder
You have to reach up above the pedals into the pedal block assembly and remove the retaining clip and pin that connects the clutch master cylinder piston shaft (#10 in diagram) to the clutch pedal. It sounds more difficult than it is. I've replaced one once but it was a while ago and I don't recall any special techniques were needed.
Incorrect!!! Pull the 2 13 mm nuts and the line, tap the clutch master and it comes right out, pin stays on pedal assembly ![Wink :wink:](./images/smilies/icon_wink.gif)
Yup - Jim's right. Sorry about that, I forgot how simple it was. And Jim was the one who told me how to do it years ago. ![Embarassed :oops:](./images/smilies/icon_redface.gif)
And I was thinking my hand was just too big and trying to convince the wife to stick her hand up there!!
Thanks you both for your answers (especially Jim )
