Clutch issue
Clutch issue
Hello. I have a problem with the clutch. It was slipping and I had a half pedal. I would press the clutch pedal and go halfway, then it feels like I'm stepping on a block. After I pulled the transmission, disk still looks pretty good. So I was thinking maybe there is something wrong with slave cylinder. The stopping halfway of the pedal seems like something is blocking travel. The throw out bearing feels rough and splines had mud on it. Nothing to stop travel. I bought a rebuild kit for the master cylinder because it has been leaking. Does anybody have any other suggestions? I did have a hard time getting push rod out the fork. Does it sound like the slave cylinder is bad? Since it's apart, I'm just going to put new clutch, pressure plate, bearings in and rebuild the master cylinder. Also, should drain hole have plug in it? Thanks. Brian
1975 710M
2000 Ural Tourist
2000 Ural Tourist
Re: Clutch issue
Earlier this spring I had to change the clutch master cylinder; it was erratic. I've now had to change the clutch master on both my trucks, but never had to mess with the slave cylinder. I'm not saying that you don't have other issues, but from my experience the master fails much more often than the slave. YMMV.
Re: Clutch issue
Ok,cool. I just wanted to see if the slave was prone to issues. Although, after 10 years on this board, I don't think I remember hearing about any time it was an issue. Thank you. Brian
1975 710M
2000 Ural Tourist
2000 Ural Tourist
- Hotzenplotz
Re: Clutch issue
just for info
the clutch slave and the locker / all wheel drive slave cylinders are interchangeable.
If you get stuck with a failing clutch slave cylinder far from home, you might decide to limp home without engaging the front wheel drive, or skipping a rear axle lock on a 712...
Albert
Albert
Re: Clutch issue
And the clutch slave is a very simple rebuild, master has a lot more parts
and assembly order. If your torn down this far why not do a compete refresh
and give that slave a new lease on life. BTW my slave failed first several
years ago, although I don't know the history on my Master by the looks of
it it appears to have never been touched -- but not for long
I am
about to replace my Master as well, has a wee bit of a leak. I am sick of
the slippy floor after a long trek![Sad :(](./images/smilies/icon_sad.gif)
![Wink :wink:](./images/smilies/icon_wink.gif)
Re: Clutch issue
I thought my slippery floor was a leaking master cylinder. Turns out is was oil working its way out of the speedometer cable. I oiled the heck out of it and over time it comes back up the cable and seeps out at the 90 degree elbow.
Re: Clutch issue
That has to be the craziest oil leak I think I've heard of. Thanks for the tip about the slave cylinders being interchangeable. That's good to know. I think I may as well rebuild it being it's the only thing left
1975 710M
2000 Ural Tourist
2000 Ural Tourist
Re: Clutch issue
For me, my oily floor has a clue
An ever so slight reduction in brake fluid in the Clutch reservoir,
and the tell wet spot on the Clutch peddle joint.
I kind'a have come to the point where I biw expect something is
going to spring a leak no matter how much you stay on top of it
But I stay on top of it.
Re: Clutch issue
Well I knew for sure the Clutch Master was leaking, but here's a PIX I just took from a Boroscope
right behind the brake assembly.
These Borescopes are pretty inexpensive and, has saveed me a lot of speculation in the past.
Note the wet boot and the boot is not actually seated properly.
Re: Clutch issue
Does anybody have any advice on how to hold the flywheel so I can torque it 250? Is there a tool that screws into spark plug hole to hold the piston at bottom dead Center?
1975 710M
2000 Ural Tourist
2000 Ural Tourist
- Hotzenplotz
Re: Clutch issue
The pulley on the front end of the crankshaft has two holes.
Stick a prybar through and you are good to go
btw : what kind of unit is 250 ? the manufacturers manual says 50 Nm and then an additional angle of 60°.
Secure with Loctite 242
Cheers !
Cheers !
Albert
Albert
- McCall Pinz
Re: Clutch issue
I used a simple aluminum bar with two bolts to the flywheel. It blocks against the studs on the engine block. I have a clutch rebuild thread somewhere here with pictures.
eat, sleep, Pinzgauer
Re: Clutch issue
Hotzenplotz wrote:The pulley on the front end of the crankshaft has two holes.
Cheers !
Hello. I found the post about the torque on flywheel. Both sources are to be trusted.
This was from McCall Pinz post on clutch removal.
"t) Block the flywheel with a super fancy aluminum bar tool bolted to the flywheel and 1 of the studs.
Now the task of bolting on the resurfaced flywheel… All I can say is WOW!. If you don’t have airtools, then buy the best socket wrench you can afford. After putting blue Loctite (medium strength) on the threads and under the head, the initial tightening with the Harbor Freight torque wrench was fine. You can see how I marked a corner on each bolt. The next 60 degree turn was a huge task. The cheap HF torque wrench with breaker bar was flexing too much to get the full turn. My shorter Proto was a lot stiffer and with the 30” breaker bar did the trick. Jim L says its 240 ft lbs. Those bolts have to be very near their elastic limits. The final few degrees of the turn go slowly and evenly- like the bolt is stretching. I’m still sore today."
So, what to do? Is Jims value after the 60° turn, what the torque would be, or is something else?. Also, if your not to reuse these bolts, how come you can buy them used? And how do you pull rear seal and replace it? I couldn't find a post about it.
1975 710M
2000 Ural Tourist
2000 Ural Tourist
- McCall Pinz
Re: Clutch issue
I replaced and torqued the bolts per the manual. Torque them once, then slowly tighten them another "point" on the hex head. The 240 ft/lbs note is from another post by Jim L. for comparison only. I don't have any way to measure the final torque value that high and wouldn't go straight up to that to torque value if I did. Reusing the bolts scares me too. You could honestly feel the bolt stretching in the last few degrees of rotation and I think the loctite is there for lubrication as much as locking in place. The bolts are expensive, but If a reused bolt snaps off in the end of your crank, then your probably SOL. The seal is quite easy to pick out with a small screwdriver and replace. Press the new one in carefully and evenly. I used a wood block and some silicone grease.
Re: Clutch issue
The flywheel bolts are designed to stretch under load to establish an accurate pre-load condition.
The low'ish initial toque is to take all the "slop" out of the interfaces only.
Applying a torque with a Torque wrench has a fair amount of inaccuracies due to thread and surface
friction, the frictional variation is large enough that each bolt would have a considerable variance vs each other.
Thus the "Angled Controlled Tightening" method is used, which results in a precise stretch on the shank of
these bolts. A 60 degree turn is 10 thousands of an inch stretch (0.27mm). I have read that bolts designed
for this purpose do have a limited number of "re-use" cycles. The problem with re-using these bolts is not
knowing how many cycles they have experienced unless you are the original owner
I'd be inclined to replace with new and keep the old as spares.
Pix below of a stretch bolt under load: RED = high stress region.
