aftermarket hi temp duct hose as furnace exhaust?
Post by audiocontr » Fri Dec 08, 2017 5:33 am
I have a small rv furnace that I'm replacing with a larger. I was considering using the RV furnace in the 712m with a small propane tank. It's that or scrap it.
Furnace manufacturers are very clear that one is not to modify the intake and exhaust. I want to modify the intake and exhaust :D. I was considering the use of hi temp silicone reinforced hose from McMaster, basically the same stuff we use as our aftermarket ducting. Intake is 2". Exhaust is 1.5"
Beyond the risk of collapse, what risks do you forsee?
(2) 1968 Haflingers 1 For Sale
1978 GMC Palm Beach
2001 F250 Diesel and trailer
Re: aftermarket hi temp duct hose as furnace exhaust?
Post by rmel » Fri Dec 08, 2017 9:45 am
Orange Silicone hose good for 450F operating temp MAX.
https://www.pegasusautoracing.com/produ ... gJqGvD_BwE
Possible you are well over that Temp just at the exit of the furnace? If still operational
you could measure the exhaust with a handheld IR temp gun from El Harbor Freight.
Rescue Pinz: 73' 712M
Post by audiocontr » Fri Dec 08, 2017 12:18 pm
275 degrees 1 inch from the output.
Great site by the way! Much cheaper than McMaster
1978 GMC Palm Beach
