Width of rear side doors on a "K" pinzgauer?
Can anyone get me a dimension of the rear door width or, preferrably, the window opening dimensions?
Looking at buying some of the sliding glass from Dave Dunn for a project I am doing.
Thanks!
Re: Width of rear side doors on a "K" pinzgauer?
I can send you that tomorrow morning. Outta town at the moment. You want the opening frame edge to frame edge or the inside jams where the felt runners are?
Really just need the outside opening size of the window in the door where the glass is.
Here you go...BOTH windows measured exactly the same
621mm x 414mm
David Dunn
Post by David Dunn »
Haf-e needs the opening size, we know the glass size. It's different than the TD door opening or I could give it.
Thanks - but as Dave said - I need the opening size to see if I can make it work with some window frames I am considering making for the side of my pinz.
That's what I had thought you would be looking for :wink:
OK, here's the new measurements.
635mm x 430mm
That would include the felt runners. I have relatively new felt
but I did keep the old ones that were in decent shape. These
measure 4.5mm from where the glass sits to the backside metal frame.
So the TOTAL metal to metal would be approximately 644mm x 439mm
Hope this helps, if you need another measurement met me know.
ron
