CV Boot Question
Uli-RT
Germany
Re: CV Boot Question
Post by Uli-RT » Mon Jan 05, 2015 3:16 pm
... I wouldn´t use a degreaser. Just wipe it out. Also inside the axlebody.
Check the venthose on top of the axlebody. May be the mud came in there.
If you find some more mud, I would flush the complete axle with oil or better dismantle it to make shure that there is no more mud inside.
chosenview
Post by chosenview » Mon Jan 05, 2015 4:35 pm
Ok thanks
Axle body is fine. Crud was just wheel carrier side. I'll wipe out what I can, fit the new boot then change the oil in the hub
Hoss
Post by Hoss » Fri Sep 30, 2016 5:41 am
Does anyone have any miles done with the FMV boots? Someone told me they had spoken with a plastics guru who said that polyurethane was not a very good material for that purpose.
I've fitted 2 and they seemed to be good quality, but i havent done any miles yet.
Uli-RT
Germany
Post by Uli-RT » Fri Oct 07, 2016 11:32 am
Hi Hoss,
the FMV boots are much better than the old original Volvo boots.
I habe them too.
Regards
Uli
Klug
Post by Klug » Wed Oct 12, 2016 3:15 am
I've received new boots (not new old stock, brand new special built) from Tatanka.
They use rubber as the original ones but are much thicker.
I have yet to put them on 8-/
dokatd
Post by dokatd » Sat Dec 03, 2016 3:26 pm
I installed a Tatanka CV boot in my brothers truck several weeks ago. It was good quality and has been working well with several hundred miles on it now. They have Tatanka molded into the boot to identify it.
bababiscuit
Post by bababiscuit » Fri Apr 20, 2018 3:16 am
Any idea what has happened to FMV4x4?…page will no longer load, if anyone knows how to reach them, I’m needing to get some more boots...thanks!
Uli-RT
Germany
Post by Uli-RT » Fri Apr 20, 2018 5:21 am
FMV is closed. No further action, as far as I know.
You can contact Claas in Germany 4scirocco(add)web.de
He has many new rebuild parts. There is no website.
Regards
Uli
bababiscuit
Post by bababiscuit » Sat Apr 21, 2018 12:10 am
Thanks Uli, much appreciated—-Erik
bababiscuit
Post by bababiscuit » Sun Apr 22, 2018 2:45 am
Looking for some feedback...my Volvo seems to go thru the cv boots pretty regularly and my rig has spacers on the wheels to provide a bit wider stance...this was something done by the previous owner and I haven’t thought to undo it, the wheels are only out an inch from under the vehicle, but could this be causing more strain somehow on the boots?...obviously the engineers at Volvo designed them the way they did for a reason, but has anyone experimented with a wider stance and had a similar experience?
Volvofan1
Germany
Post by Volvofan1 » Mon Apr 23, 2018 3:25 am
Hello,
as Uli mentiones the last days.
I have the CV-Boots in stock.
Good quality, new, similar to the boots from Morgan.
And a lot of other parts for the Volvos (sealings, bearings, brake parts, CV-boots and so on).
regards Claas
