Volvo C303 - uneven braking
Sgray
New Zealand
Post by Sgray » Wed Oct 03, 2018 5:36 pm
Hi all Portal Hub enthusiasts.
My name is Steve, I live in New Zealand and I bought recently a very clean and well maintained 1978 C303 ex Swedish military radio vehicle. I think it is the only one in the country.
I have a problem with the brakes. Front wheel cylinders replaced two weeks ago, back wheel cylinders replaced about 18 months back...all brake linings near new and brakes bled according to workshop manual. All work carried out by very competent and trusted workshop however the mechanic cannot get the vehicle to have even stopping power. Mechanic thinks there may be an issue in the servos however, if anyone has advice or foresight on this issue I would be very grateful.
Thanking you in anticipation.
Re: Volvo C303 - uneven braking
Post by rmel » Wed Oct 03, 2018 7:08 pm
Can you describe what you mean by "even stopping power"?
For instance heavy braking results in a pull to one side or the other?
If that's the problem, this is actually dangerous. I don't know
much about Volvo brakes, but on the Pinz that's an indication
of the shoes being too loose on one side. I recently had this
problem and fixed it with one more click tightening on the
left front shoes.
Rescue Pinz: 73' 712M
Sgray
New Zealand
Post by Sgray » Wed Oct 03, 2018 10:29 pm
Thanks rmel. i meant the truck pulls to the left... not suddenly but gradually...enough to make it fail the 'road worthy' test or what we call a warrant of fitness (WOF).
All vehicles in NZ have to pass a WOF test every 6 months to be legal on our roads.
The brake shoes have all been correctly adjusted to the brake drums but we still have the problem of one side ending up with more force than the opposite side. Its possible the rear brakes are locking up too. Very confusing!
Uli-RT
Germany
Post by Uli-RT » Thu Oct 04, 2018 1:33 pm
If the pressure in all tires is the same I first would give the right side one more klick to the brake shoes.
You have to try that out. May be there is only one brakeshoe possible to move nearer to the drum.
Sgray
New Zealand
Post by Sgray » Fri Oct 05, 2018 4:38 am
Thanks Uli-RT
Will check it out.
Andre
Post by Andre » Wed Oct 10, 2018 10:50 am
Look at your vacuum boosters under the engine cover. One may not be functioning properly.
(903) 717-4018 shop
(951) 765-7224 cell
74 710m and (1) pinz trailer
Sgray
New Zealand
Post by Sgray » Wed Oct 10, 2018 5:42 pm
Thanks Andre.
Appreciate all the feedback from people.
The servos were in the back of my mind...we are still working on the brakes.
I'll let you know what the outcome is when problem overcome.
dokatd
Post by dokatd » Wed Oct 10, 2018 6:42 pm
Brake servos should be effecting front to back, not side to side.
Possible the mech didn’t understand the bleeding procedure for the front and back interconnected lines. Each back wheel brake activates one of the wheel cylinders on the opposite front tire.
roobar_and_custard
Post by roobar_and_custard » Wed Oct 10, 2018 8:38 pm
Based on the brake circuit diagram for a TGB11, if one servo was weak there would be differential braking performance on the rear wheels only, the fronts would stay balanced. This might cause the car to drag to one side under braking?
TGB11 Brake Circuit.JPG (53.96 KiB) Viewed 1048 times
Sgray
New Zealand
Post by Sgray » Thu Oct 11, 2018 3:40 am
Thanks to robber_and_custard & dokatd for valuable information/diagram.
Mechanic aware of these points and I had given him a full workshop manual (in English!).
If servos the problem...can anyone recommend where to obtain servo rebuild kit/reco unit etc?
I've perused Tatanka website and aware of replacement brake servo cylinders for sale...possibly another supplier out there?
Regards SG
Uli-RT
Germany
Post by Uli-RT » Thu Oct 11, 2018 1:36 pm
If you need any repairkits you can call "Friese"=Claas in Germany on the German C303-Forum:
https://www.c303.de/c303-forum/index.ph ... #msg113203
Sgray
New Zealand
Post by Sgray » Thu Oct 11, 2018 4:11 pm
Thanks Uli-RT, appreciated.
Sgray
New Zealand
Post by Sgray » Thu Nov 29, 2018 11:01 pm
Dear All.
I wanted to sincerely thank all the people who contributed to my C303 technical issue with the brakes.
The problem is solved through a combination of relining all rear brakes shoes, copious bleeding procedure and adjustments.
The brake pedal remains spongy but the truck stops in a straight line and is now road legal.
My intention is to sell the truck so if any interest keep an eye out on The Portal Hub's 'For Sale' section.
Kind Regards
SG
