Idle Problem
Hersir
Idle Problem
Post by Hersir » Sat Jun 15, 2019 9:51 am
Lately, my Pinz has had trouble idling reliably and stalls unless I have the Starter pulled out an inch or more, even after warming up. I've checked each carburetor solenoid and replaced the coil, which has now exhausted my very limited skills. Any thoughts on where to check next? Thanks!
Sent from my SM-G965U using Tapatalk
1975 710M (Swiss)
Re: Idle Problem
Post by edzz » Sat Jun 15, 2019 11:28 am
1. Check in the distributor and insure that the centrifugal advance is functioning properly.
2. Stale gas?
McCall Pinz
Re: Idle Problem
Post by McCall Pinz » Sun Jun 16, 2019 4:56 pm
Did it come on quickly or slowly over time? If it occurred slowly over time and Starter/Choke helps, then I would think of starting with the carbs.
edit- I almost forgot my favorite instant tune-up- clean the spark plugs, re-gap them, re-install, and see if that fixes it. My #3 plug fouls pretty quickly and the whole thing runs poorly with a variety of symptoms until its cleaned and purrs again.
eat, sleep, Pinzgauer
BobbyD
Re: Idle Problem
Post by BobbyD » Mon Jun 17, 2019 7:43 pm
Since I do not have the SSI kit installed, my order of solving (this when it happens to me) is this...
  • Clean distributor contacts/remove moisture
  • Check molex connector... make triple sure that all those contacts are clean and engaged. On mine it looked fine, until I removed the air shroud and then could see that there was corrosion on "the other" side.
  • Solenoid connections
  • Solenoids themselves
  • Carbs
The farthest I have had to go so far is Solenoids.
1971 710K S
N2PNZ
Re: Idle Problem
Post by pinzinator » Wed Jun 19, 2019 9:51 am
Check the vacuum line that goes to the distributor. It could be cracked or disconnected.
Hersir
Re: Idle Problem
Post by Hersir » Wed Jun 19, 2019 10:16 am
Thank you, all. I'll work through these recommendations and report back.
1975 710M (Swiss)
