Flywheel position for balance
boeing7873
Argentina
Post by boeing7873 »
In my quest for removing all leaks I removed the flywheel to change the crankshaft oil seal (which was completely dry). When I removed the flywheel, I marked one tooth and a corresponding location in the engine timing gear cover plate. Then I figured that the leak came from the gasket between the block and the timing gears cover plate, so I removed it, and proceeded to wash it, that included washing the mark for the position of the flywheel.
Now I can only guess its original position. Is the flywheel balanced with the crankshaft or can I assume it can take any position?
Many thanks for any input.
Jerome
CRJ Driver
Hotzenplotz
Austria
Re: Flywheel position for balance
Post by Hotzenplotz »
As far as I know the flywheel is balanced independently from the crankshaft.
I had to take mine off to replace the worn gear ring and did not find any reference in the Austrian Army maintenance manual to mark the position.
Hope that gives you peace of mind :-)
Albert
boeing7873
Argentina
Thank you! Truck runs just like before, no vibrations noted.
Jerome
CRJ Driver
