Heat duct
Heat duct
Hello. Has anyone used exhaust flex pipe for heater ducting? Both the small diameter and large diameter tubing? I think that it would be insulated more than the cloth flex tubing. Thank you. Brian
1975 710M
2000 Ural Tourist
2000 Ural Tourist
Lightningpinz
Haven't tried it because it in my humble opinion that would be much worse than cloth wrapped ducting. The steel would be an excellent conductor of heat. This would cool the heated air in it's travel to the front. If you were to insulate the flex exhaust pipe before you install it. That should make up for the conductivity of the steel pipe. I am running some flexible "plastic" pipe that Dennis got. It is about 1/8" thick stuff with a wire like a dryer duct. I'm running it from the heater box to the valve. It cost if memory serves about $2.00 per foot. I'll get more later and wrap it with duct tape or aluminized insulating wrap or something and run to the front. Check around, call around and see what you can get. Don't limit your search by what has been done.
Five years a go I needed to insulate the heater hose better like most of us in the colder states.
I decided to replace the old hose and insert the new hose in a slightly larger aluminum flex hose as a protective shield and insulator. (An air space is created between the smaller inner hose and the larger outer aluminum flex hose) I did not clamp the aluminum flex hose end because I wanted any water that got into the hose system to be able to drain/dry out.
It has worked very well as an insulator and the difference very noticeable.
Ken A.
Ken A.
Brian Double wall pipe would cut down a little bit on heat transfor. I like the idea of plastic pipe but would be worried about the melting point of it. John do you now what the melting point is? do you have a data sheet? Lowes carries a flex double wall pipe close to the same size http://www.lowes.com/lowes/lkn?action=p ... lpage=none when i finally get around to installing my gas heater I plan on having stainless steel bent and insulated.
- McCall Pinz
The Lowe's vent you linked to is Class B vent for gas water heaters and furnaces and should handle the heat. I think its rated to about 350 degreesErik Maybee wrote:Lowes carries a flex double wall pipe close to the same size http://www.lowes.com/lowes/lkn?action=p ... lpage=none
Lightningpinz
Have no data sheet for the plastic pipe. Has been on summer and winter now. I tend to push shifts in the mountains at max posted speeds on the console. Up and Down shifts at max speed for power in the mountains. I also run 104 kilos per hour for 5 or six hours from Denver to Grand Junction. So assume the heat rating is adequate for a Pinz. I have tried the aluminized duct/emission system ducting for the heat riser tube. It lasted about 3/4 of a year. The flexing of the engine killed it in one spot and rubbing around a radius wore thru in another.
Willard Foley
http://www.selbyboatcentre.co.uk/chandl ... cts_id=143 I thought i might post this I have placed an order and will to see how it works.
Heat duct.
That looks like the ticket. Wish I would have seen that a week ago. Let me know. I wont install my new tubing till I hear from ya. Brian
1975 710M
2000 Ural Tourist
2000 Ural Tourist
