Hafi Heavy Cleaning - lots of photos
Been busy but getting through some stuff - so slow!
Oct 1st-5th away in Kansas City for American Royal BBQ Comp :mrgreen:
Garrycol
Post by Garrycol »
TechMOGogy wrote:Oct 1st-5th away in Kansas City for American Royal BBQ Comp :mrgreen:
You have your priorities all wrong - Haffies always come first not BBQs :D
garry
1973 Haflinger AP700
1977 Landrover FC 101
2007 Range Rover Sport TDV6
1957 Landrover 88"
Yakov
Post by Yakov »
While you have your steering box out, you should check the condition of the tube that carries the horn wire up to the steering wheel button. It's welded onto the bottom plate on the gearbox. My horn wire "conduit" rusted out and is now leaking steering gearbox oil out onto the floor...
My theory is that this happened to me as a result of no button being present to cover that tube and the vehicle being left out in the elements.
1972 Steyr-Puch Haflinger
1984 VW\Bombardier Iltis
Striped and rebuilt it last year or was it the year before :mrgreen:
Like I said - process is soooo slow!
I agree - good thing to check and your most likely correct re: the open tube
It seems to me that I used Mercedes tie rod ends out of a '76 240D as replacements for my Haflinger. Not expensive and easy to find new. Also, a Pinzgauer steering wheel will fit on a Haflinger column.
pinzinator wrote:It seems to me that I used Mercedes tie rod ends out of a '76 240D as replacements for my Haflinger. Not expensive and easy to find new. Also, a Pinzgauer steering wheel will fit on a Haflinger column.
'74 :mrgreen:
I bookmarked your thread!
http://real4x4forums.com/PinzgauerBBS/v ... f=7&t=5840
Heinkeljb
Post by Heinkeljb »
When are you going to start putting it together? All very well taking things apart - but don't you want to drive it?
John
Heinkeljb wrote:When are you going to start putting it together? All very well taking things apart - but don't you want to drive it?
John
Yes but seeing as I only get a hour or 2 a week it is just taking forever.
Half the problem is me and just making things as good (hopefully better) than factor new. Just something in me and at times it pisses me off as it just means more work = more time.
One day it will start to go back together and I can't wait to drive it on the 1000's of KMs of ATV trails we have here!
Finally some parts ready for paint
The shock/spring towers, springs and a few other parts are off at the powder coater
Found some 1mm and 0.5mm shims for when I do the hubs/gears.
Not much but finally some paint!
Hafi 1 Mine Restore6.jpg (108.86 KiB) Viewed 2181 times
Miss it being in one piece esp since it was 62 degrees today!!!
Tech
Heinkeljb
Post by Heinkeljb »
Well, there's only one person to blame!
Pull your finger out and start putting it back together..... I am sure there are a lot of other Haflingers out there that are in the same situation!
I have servicing / checking to do on Lurch before driving him to Holland and back for a Treffen in May.
John
Hey I don't dispute it - just life getting in the way.
Heinkeljb
Post by Heinkeljb »
Well, if I pull your leg hard enough, you might get round to re-assembling it! :P
John
Garrycol
Post by Garrycol »
Nice pretty parts - wont look like that for long once it is back together and in use :lol:
1957 Landrover 88"
