Installing new Master Brake Cylinder
Issues with shocks/springs, tires, stopping, etc.
PittsPinz
Post by PittsPinz » Sat Apr 07, 2018 5:58 pm
Just knew something would go wrong.
After installing master, I was connecting the brake lines and stripped part # 7101364671, plug adapter M10x1/M12x1x24.
TRICK to all future installers.
Attach lines to Master BEFORE attaching Master to the brake booster.
Need new part now.
SAV? $19.50
Any other suggestions?
Thought about trying to rethread but it's brass.
Thx
Re: Installing new Master Brake Cylinder
Post by Haf-e » Sat Apr 07, 2018 9:23 pm
Do you mean the adapter fitting under the residual pressure valve #33.2?
I think I've always done it after the master was fully installed and connected to the booster. Which side stripped?
Not sure how you would attach the lines to the cylinder before attaching the master to the booster since the brake lines are hard and not very movable...
BTW - did you "bench bleed" the new master cylinder before installing it?
Post by Haf-e » Sat Apr 07, 2018 9:39 pm
Here is a good image - from Expedition-Imports parts website:
7103366220 Expedition Imports.JPG (249.26 KiB) Viewed 2170 times
I added the text to the image.
https://expedition-imports.com/7103366220
