Electric Fuel Pump
Electric Fuel Pump
I tried to find another topic on this issue with no luck. Has anyone gone to an electric fuel pump with any luck? If you did what fuel pump do you recommend.
I replaced my mechanical pump with a unit from Aircraft Spruce.
http://www.aircraftspruce.com/catalog/e ... tpumps.php
PN# 40164 - 24V Neg. Ground, 4-C PSI Max, 30 GPH, 1/8 x 27 internal pipe ports
I found a simple way and location for mounting. I have not yet had time to send the pictures and my procedure to Jurgen.
It works fine, I have had no performance issues so far. (Installed it in early November)
Ken
Ken
