What is this part of heat exchanger for?
Posted: Thu Nov 14, 2013 1:04 pm
I can't figure out from drawing what this is extra outlet is for?
https://real4x4forums.com/PinzgauerBBS/
Yes it is though I've not seen a heat exchanger with that port operational. My pre-heaters connect to the heater valve (item #61).mm58 wrote:Is that the one for the air intake pre-heater(?)
undysworld wrote:There's a grill on the wall above the access port in the rear floor on a K. Is it possible this is a variant for that truck?
