Doetsch shocks
ka
Post by ka »
has anyone talked with anyone at the shock place who is an authority on these shocks? they are mono tube?
1973 710m
STPPINZ
Post by STPPINZ »
One question with these Dutchtech Shocks. I installed mine and the exposed rod is is even shorter than the pictures that Jim posted. How much length is needed for the shock not to bottom out while performing? I havn't used them off road so I don't know if they bottom out yet.
This may push me into doing what I have been wanting to do for a while and find some new front springs...
Wimps Need Not Apply
Yes, you need springs :cry:
STPPINZ
Post by STPPINZ »
Jim LaGuardia wrote:Yes, you need springs :cry:
I agree with you Jim, I do need springs. But even in your pictures with your axel almost free swinging, there isn't much room for travel for those shocks... I am assuming with the tire on the hub and the weight of the truck, you could be in the same position. Could the shock body be to long?
No, they are not too long. They are the same lenth as the stock shocks and have identical travel.
loyalp
Post by loyalp »
Just replaced all four of these yesterday:
The Doetsch shocks have now made the ride very nice.
Mine were Monroe shocks made in Belgium.
JNijst
Netherlands
Adjustable shocks
Post by JNijst »
Gentlemen,
Is there any way that these Doetsch shocks can be made adjustable, like the Rancho's ?
There should be a way to pump oil in/out the reservoir. I have asked Doetsch, but no answer on my email...
I like the idea of adjusting shocks for on-road and for off-road. I still have the original shocks and the Pinz does sway about sharply when hitting road-bumps (intended to slow the traffic)
Jules
Pinz of rock - 710M / 1975 (Austrian Army)
Pinz Enthusiast
Post by Pinz Enthusiast »
Just put my shocks on today, wow what a difference in ride quality, and I havent even been in the dirt yet (going to Big bear Thursday), as a tech note for the front shocks I would recomend driving the bolts into the top bushings a time or two to loosen them up a bit so when you go to install the bolt it slips right in I also put a little lube or grease on the bushing to help as well, whole job took about 2.5 hours and I even stopped to change my spark plugs while I was there..... here is a few shots
Eric
Anaheim Hills, Ca
1996 LR Disco I
2003 LR Discovery SE
hope to get a 1969 Ford M656
