windshield
David Dunn
Post by David Dunn »
To be on the safe side, remove the door tops and lay them on a towel to replace the glass..... gravity is less likely to make for a bad day. :wink:
David Dunn
Received the first shipment of tinted door glasses today... just waiting for that first 710/12 to put them into. :D Have sets for Ms and Ks.
Dave Dunn
2012
Post by 2012 »
how much?
David Dunn
Prices are on the previous page
David Dunn
FORKLIFT- The other windshield removing tool!
Note- No Pinzes were hurt during the filming ..... but maybe I should have had the driver get out beforehand. :roll: :wink:
lindenengineering
Post by lindenengineering »
Watch out for those forks!!
Patrick at Cold War had a yard man put a set of forks through the side of a Pinz, in short squewerd! Not pretty and a bit expensive to fix.
In that incidence no-one got hurt, just some pride and pocket money!
Dennis
OOOps no customer bashing now
EvanH
Post by EvanH »
Ok, Dave, if you can install one the same way l will be REALLY impressed!!! :D
-Evan
MarkPinz
Post by MarkPinz »
Even with the advanced installation technique :shock:
My K is very happy with the set of Dave's new windows :D
Just get in and go....
ktmkirk
alternate source needed for side window trim piece
Post by ktmkirk »
David, Do you know or someone else on the forum know where I can get that little trim piece that goes on the edge of one of the side windows of the Pinzgauer, I received one from SAV but the other side is backordered. ANy suggestions, I am going to try some Auto trim places but I'm not sure if there is already a repalcement for this peice that is readily available...Kirk
[quote="David Dunn"]To be on the safe side, remove the door tops and lay them on a towel to replace the glass..... gravity is less likely to make for a bad day. :wink:[/quote]
David Dunn
Kirk
I'm not sure I understand what trim piece you're refering to. The felt tracks? Do you have the part number?
Dave Dunn
ktmkirk
Post by ktmkirk »
SAV only had one peice and the other peice is backordered it is called a seal strip ,part# 7111761681 and is the vertical peice that goes on the edge of one of the sliding windows that acts as a seal between the two windows
[quote="David Dunn"]Kirk
Dave Dunn[/quote]
Locked
