Transmission 710 - 712 are they different?
Is there any difference between the 710 & 712 in the transmission or high low box?
Also who got the new trans that was up for auction on ebay? Jim?
Miles
Miles
- David Dunn
Tranny is the same. The T case is 12% lower in the 712 in both ranges.
710 .88 :1.0 high, 1.69:1.0 low
712 1.0 :1.0 high 1.92:1.0 low
This is off the top of my head.
I would have liked to have that tranny. it was for a 716
- David Dunn
Why, Dave? Do you need more torque for climbing? But, it would be a bit worse on highway.David Dunn wrote:I would have liked to have that tranny. it was for a 716
At the moment, I am happy with the stock tranny and automatic transmission. A lot of torque for climbing, even if fuel consupmtion is 710-like.
Regards,
Ugo
- David Dunn
Ugo, I think you missed something, that was a stock 716 tranny.Ugo wrote:Why, Dave? Do you need more torque for climbing? But, it would be a bit worse on highway.David Dunn wrote:I would have liked to have that tranny. it was for a 716
Regards,
Ugo
- David Dunn
Ugo
Actually talking to Peter the other day, and we felt a 6 or 7 speed for the Pinz would be nice. It would get rid of some of the "long leg" in the upper gears. A low granny gear, an OD, and closer intermediate gears.... but , you don't need to worry about that with your slush box.
Dave Dunn
Dave Dunn
Higher Tranny gears
The TD tranny is 33% higher in overdrive, but only 25% higher than the gasser's first. That puts the crawler about midway between the stock first and second. Since my W spends most of its time on the freeway/dirt roads, no real heavy offroading, I think I'll like the TD tranny...
Ford has a six speed manual in their trucks that has about the right gearing - 20% overdrive, and a low that is 8% lower - lower low, higher hi, but would it fit? I REALLY wanted a Gear Vendors overdrive so I could spit gears. The numbers looked great, but it's just too long to fit. Oh well.
712W (with EFI and soon to have TD tranny!) and stock 710M
- David Dunn
Jim
I had done a OD tranny in a 712M years ago. The ratios were really off, had to use 1st for takeoff more often than not. In town was usually the bottom 3 gears, and downshifted out of 5th for power on the hiway. If I hadn't sold the truck, I would have gone back to the original trans. The OD trans belongs with the TD's T case
Dave Dunn
Dave Dunn
How hard is it to swap the t-cases?I often think the lower gearing for a 710 would be a plus.The 712 with it's x-tra traction could get by off road with a 710 case and would make it more "roadable ". As I have one of each,and if it was not a real bother,I would like to experiment with some swapping to find out for myself.
..... :idea: Someone get serious about my X-Tra K so I can remove these thoughts from my head!
TTFN,Mark
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
68 Haffy
