Spare Wheel Cover with Emblems
Locked
grayroad
Post by grayroad »
I liked the painted emblems on the front so much that I made a set for the rear. If anyone is interested I can tell you how my son-in-law put the "wheel cover" or "hubcap" on.
Foz
Post by Foz »
Ya... how did he do dat?
Foz
grayroad
Wheel Cover
Post by grayroad »
He welded a nut to the circular steel plate, then welded a slotted bracket to the triangular bracket that holds the spare wheel. I painted the emblems and the circular plate and used a threaded rod secured with nuts to the slotted bracket to attach the circular plate. I just spun it on tight and eyeballed the locations for the emblems, took it off again and drilled holes to bolt them on.
Charles
Post by Charles »
Hi,
Sweeeet. I'm more interested to know:
1)Where you got the emblems to make the cover ("hubcap")
2) If you can't tell me that, how much you'd charge to make one for me...
Nice work.
Seeya
Best Regards,
Charles
('73 710K)
PS: Keep your stick on the ice
grayroad
Emblems
Post by grayroad »
SAV has the emblems. They are not very expensive but they come OD. I hand painted them and those on the front of my 712M.
Cory Gray
Locked
