Ignition Noise on AM Radio
Locked
hrafn
Post by hrafn »
I installed the civilian ignition kit from Expedition Imports and now I have a
lot of noise on my AM radio (FM is ok). Has anybody else experienced this,
and has anybody found a cure?
As a side note, does anybody know if Scott's civilian ignition kit has the
resistor in the wires, or in the spark plugs?
Jay
W3PNZ
710K Kommandowagen
Lightningpinz
Post by Lightningpinz »
Hey Jay, my civi kit was from about 2001. It has resistor wires. I've had no problems. (well, my cb is noisey. However when you smack it , the problem gets better. I think there is a daughter board loose inside.)Having said that I would check and ensure that each plug wire has good contact on the spark plug. (twist, push and feel the click). If that doesn't work, then remove 1 wire at a time and see if any 1 wire has a noticeable effect on the static. If one wire has a noticeable effect, then check that wire and plug. Also check the grounding of the radio and the antennea.
Best of luck. Let us know how you get along.
M Wehrman
Post by M Wehrman »
AM.. :shock: I know what FM is ,also sat radio,cable TV,Windows,I-tunes and Pertronix....I thought AM was natuarally full of static....... :lol: :lol:
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
kc4mne
Post by kc4mne »
I can hear big time static on my ham radio gear after installing scotts kit also. Hve not tried to troubleshoot.
Please post any fixes that you come up with
Charles
Post by Charles »
Hey Jay,
Yah, I have the same problem. I do believe it comes down to two things:
1) Poorly grounded antennaes (as suggested)
2) More EMF getting thrown off now that my wires aren't shielded.
Things that I'm gonna do:
1) Ground the antennaes well (and I used to have an internal antennae that is now routed OUT of the vehicle)
2) Faraday cage inside the doghouse & cover. Just glue/foam some bronze/iron/steel/dense screen inside and ground it to the chassis. That will soak up all the EMF you care to generate in there...
Seeya and good luck.
Best Regards,
Charles
('73 710K)
PS: Keep your stick on the ice
Twin Pinzies
Post by Twin Pinzies »
AM radio still exists?! Well I'll be damned!
2012
Post by 2012 »
doesn't emf stand for electro-magnetic force?
hrafn
Post by hrafn »
Yep, sure does.
Some of the best stations around here are still AM.
That's also part of the reason for my inquiry. I may need to go back to the
original military setup before installing any ham radio gear. Anybody want
to buy a slightly used civilian setup?
Jay
W3PNZ
710K Kommandowagen
Charles
Post by Charles »
Hi Guys,
Yeah, EMF also stands for Electro-motive force (neuroscience / chemistry) it can also stand for electro-magnetic FIELDS...
I wouldn't give up on your civilian setup until I tried a few tricks (grounding and shielding). I really love my civie ignition system, spark, wires, coil and all...
Anyhoo, screen is cheap and good ground wires are even cheaper. No sense throwin' the baby out with the bathwater.
Well, I'll try the experiment my own self and keep you posted...
PS: Winter's a-comin' round these parts. I smell another post or two on insulating the Pinz in the works...
Best Regards,
Charles
('73 710K)
2012
Post by 2012 »
polyisocyanurate sheet with reflective backing is awesome stuff in a vehicle.
http://en.wikipedia.org/wiki/Polyisocyanurate
milesdzyn
Post by milesdzyn »
Jay, kc4mne.....I have zero experience with mobile based ham radio equipment and would like to know what you guys are running? Also what is the range and what type of antenna do you guys have for them? Are they compact units HxWxD?
Miles
hrafn
Post by hrafn »
Miles,
My 710K is equipped with the original radios, a RT-524 transceiver, a R-422 receiver, and the AM-1780 intercom system. Also has the original antennas.
Only good for the 6 meter band, but everybody in our MV group has pretty much the same configuration.
Jay
W3PNZ
710K Kommandowagen
2012
Post by 2012 »
where did you get that pinz?!
milesdzyn
Post by milesdzyn »
Okay so 6 meters is band width? I saw a Radio Shack mobile 10 meter Ham, would that cover the same band width as your 6 meter? Its a small package which I like, but does that mean its going to have less power/distance capabilities? What means of measure indicates power/distance?
Miles
Locked
