Sticker residue on speedo cover
Hawkeye Pinz
The plastic cover on my Pinz's speedo has alot of residue left from the max speed sticker that was on it
. I can still read it buts it's kinda crappy looking. I tried using an adhesive remover on it to no avail. Anybody out there have any advice on how to get this off my speedo? I don't want to buy a new unit as this one works fine.
speedo cover
I have used finger nail polish remover to get off adhesive residue from lots of stuff. Works great, it is cheap and may even be somewhere around the house. Ask if you can 'borrow' a little from your roomie.
Check a small area as a caution.
Morris
Morris
I agree with chapel, use a little petroleum based solvent to remove the "sticky" stuff, kerosene works well. Then clean with rubbing alcohol or detergent.
If the lense is scratched use a little plexiglas cleaner/polish.
I have used this method on glass and plastics with good results!
JohnGelbert
I tried the amonia trick several years ago and it worked like a charm
.... let it soak in just enough liquid to cover the lens for a day. It completly removed the decal and the adhesive. I'm still using the same gauge today. BTW, I used aircraft windshield polish to clean up the lense afterward.
John
