Bad Brake Switch?
Bad Brake Switch?
Now that I have LED tail lights. The brake lights on the back seem to flash and come on intermitaly, even when the truck is sitting still and the brake pedal is not moving. Bad brake switch is my guess? I looked at the schematic and found the wires. But where is the switch located? How do you replace it?
Any help would be apreciated.
Scooter
Scooter
I was forever having problems with the hydraulic brake switch .... something I put down to the fact that I use silicon brake fluid ("maybe" it was migrating into the internal workings/contacts or something) as nobody else seemed to have anywhere near the failure's I did.
Replacement was a "b*^*&" given my Pinny is RHD, so I cured the problem by fitting a mechanical switch to the pedal box .... and all's been sweet ever since!
....so "if" anybody is using silicon fluid keep an eye on the standard switch.
1997, 718 6X6 Pinzgauer
Well I have been trying to find the problem with the intermitant flash on the brake lights. It seem the brake switch has some votage going thru it even when not used. I has about 1.5 to 2 volts on the meter at times. My guess it should always read "0" when not used. I am thinking there is a contact going bad or something make contact when the brake is not pressed.
Is the brake switch wet or dry? Can it be removed without loosing the brake fluid? I want to replace it, but not sure how? thanks for the help.
Scooter
Scooter
