Adding Pictures to Posts
Locked
SAM. C.
Post by SAM. C. »
Hi All
I am sure this is a stupid question but can someone tell me how to add an image to a post please?
Sam
Post by Jim LaGuardia »
The bell flange wears out, change over to the flex coupler Kit From SAV , it will greatly reduce exhaust noise and smell :!:
Cheers, Jim LaGuardia
"Arch Magus of Machines."
First they must be stored online , I use photobucket most of the time.
Just copy and paste a link into your message , there should be[img]before and after the link, then it will work. Pictures should be 640x480 Max in size :wink:
SAM. C.
Hi Jim
Post by SAM. C. »
Thanks mate? You knew what I was on about without the picture!
Sam
Hi Sam,
The flex kit that Jim suggested is great! I installed it about 3 weeks ago and the improvement is fantastic. Part #SAV6894.
Just be very careful when removing the headers as those studs can snap off very easily if they are heavily rusted/corroded. Not fun.
Best,
Paul
SAM. C.
Headers
Post by SAM. C. »
Do I need to remove the manifold to fit this kit?
I just ordered it and it says there is a small modification needed to the exhaust. Does anyone know what this mod is?
Sam
Foz
Post by Foz »
is your leak at the head?
Foz
You have to carefully grind off the seal ring lands, they are only welded on the back side.
SAM. C.
Exhaust Blow
Post by SAM. C. »
Thanks Guys I have soaked all of the fasteners with WD40 and will give them a good soaking for the next week until my flex kit arrives. The leak is at the ferrule joint on the end of the manifold where it joins the main exhaust. It is the top one of the two pipes that is leaking.
Jim I think I understand what you mean with regard to grinding through the welds. I think that should be no hassle.
Thanks again.
Sam
Kiwibru
Post by Kiwibru »
Ok, I have heard this both ways now so some clarification is in order.
If you can grind off the required raised lands is it ok to then just weld the flex coupling onto the exhause manifold while it is attached to the engine?
I had been led to understand that the manifolds are to be removed to do this flex pipe welding?
I have this on my "to do list" as my stock system was removed (probably long rusted out) and a short glass pack muffler was cobbled onto the stock header pipes and heater pipe. Of course it leaks and is very loud. Kind of reminds me of my air cooled VW bus days when a tuned exhaust was desired and cool. I despise having to wear ear plugs to drive the rig though so that has to change!
1975 710M
Kiwibru wrote:If you can grind off the required raised lands is it ok to then just weld the flex coupling onto the exhause manifold while it is attached to the engine?
Due to the tight area around the manifold ends it is almost imperative to remove the manifolds in order to grind off the ring retainers. I say "almost" because I suppose with enough determination (more than I had), the grinding could be done with the manifolds installed.
The flex coupling kit from SAV comes with clamps for attaching the coupling to the manifolds. I imagine the kit from EI does also.
Hope this clarifies.
Paul
Kiwibru
Post by Kiwibru »
Dremel grinder work!
1975 710M
Locked
