Towbars
Trailer Pulling Thingy
Hi Evan
I think you call it a trailer hitch over there? Yes I mean the ball and its mount. I want to be able to pull a normal trailer if possible.
Have you made some mods?
Sam
Sam
SAV Bracket
Hi Mike
Looks great, but it dosent look like it addresses any height issues with towing hitches on civvy trailers. Would you just have an insert with the ball on that drops the ball a few inches?
Yes, there are many choices on drop hitches , Hench the term "hitch reciever " I use a 3'' drop, and a 14" drop for my needs
Scott also sells the hitch adaptor http://www.expedition-imports.com
Drop Hitches
Is the casting the bracket it is bolted to strong enough then even with the increased leverage from the drop bracket?
Sam
Sam
Hello Sam,
Here is a setup that we use in Europe. It works fine for normal civilian trailers. I have build myself an adaptor plate which allows me to move this particular trailer hitch up to 3 inches up or down.
And here is the link to the website http://www.pinzi-shop.de/html/zubehor.html => Scroll about half way down
Good luck,
Jacques
Good luck,
Jacques
hitch receiver
I got the hitch receiver shown above, and use the combination hitch fron Northern Tool that is a pintle and a ball together. Works for civie and military. ...but the OEM hitch is somewhat better for shock absorbing qualities, (per Alex, at EI).
Morris
Morris
has performed excellent for me
